Software Archive
Read-only legacy content
Error while executing the startup script on Mac OS
Zhuangfei_K_
I am installing Composer XE on my MacBook Air. The install package fails to work, showing "Make sure that you have write permissions to /Users/Shared/Library/Application Support"
sudo open won't work either.
What should I do then?
MalReddy_Y_Intel
Seems it is an old issue, enabling the write permissions for the directory /Users/Shared/Library/Application Support could be the solution as mentioned in the below article.
https://software.intel.com/en-us/articles/error-while-copying-license-file-intelr-compilers-for-mac-os-x
Reddy
Zhuangfei_K_
Thank you for your response. But well I have tried chmod a+w for the folders in question, but still it would not work...
Zhuangfei
