Software Archive
Read-only legacy content
17060 Discussions
'Error while extracting file' when installed the compiler ??
tianjr2003
when i double click the file named 'w_cproc_p_11.1.048.exe' to install the compiler,there is an error occured
it said that 'Error while extracting file:d:\intel\autorun.inf Access to d:\intel\autorun.inf was denied'
how can i install the compiler ??
TimP
If the file didn't download successfully, you'll have to restart or repeat the download.
JenniferJ
Can you create a new subfolder under "d:intel"? make sure the permission allows for writting & creating new folders.
Jennifer
JenniferJ
BTW. I've moved your issue posting to the right group to help you.
Jennifer
Lina_L_Intel
Greetings,
Could you please re-download the package with the download manager to see if it helps?
Thank you.
Lina
