Software Archive
Read-only legacy content
17061 Discussions
Evaluation C++ refuses to work
Bob_W_1
We have an evaluation version of Intel Fortran/C++.  When I try to run the 64 bit C++ compiler I get this:
icl: error #10310: Failed to enable trusted storage check for licensing: WARNING: Enable Trusted Storage failed (flexnet error code 20). Trusted Storage based license could not be supported
So what are we supposed to do?
Bob_W_1
So am I to take it that if we install the evaluation version of Intel C++/Fortran that we can only use the 32 bit compilers, the 64 bit compilers are basically there for show?
Hubert_H_Intel
Bob,
There is a knowledge base article about that problem: https://software.intel.com/en-us/articles/evaluation-license-error-10310-failed-to-enable-trusted-storage-check-for-licensing
Unfortunately your eval license has expired yesterday. I'll create a new eval for you due to the problems so that you can continue evaluation. Please follow the steps in the article above to install the license file.
Regards, Hubert.
Hubert_H_Intel
Bob,
I've sent you a new eval license.
Regards, Hubert.
