I am currently evaluating Parallel Studio XE 2011. I started the evaluation yesterday around 5PM. Today around mid-day, every compile command in VS2010 tells me:
1>1> Error: A license for CComp is not available (-5,357).1>1>1> Make sure that a license file is being used that contains a license1>1> for the requested feature. If your license requires a license server,1>1> make sure that the server is using the right license file (usually,1>1> this would be the same license file that is being used by this1>1> application), and make sure that you have not changed the license1>1> file since starting the server.1>1>1>1> License file(s) used were (in this order):1>1> 1. Trusted Storage1> 2. C:\\Program Files (x86)\\Common Files\\Intel\\Licenses\\.lic 1> 3. C:\\Program Files\\Common Files\\Intel\\Licenses1> 4. C:\\PROGRA~2\\Intel\\COMPOS~1\\bin\\Intel64\\*.lic1>1>1> Please visit http://software.intel.com/sites/support/ if you require technical assistance.1>1>1>icl : error #10052: could not checkout FLEXlm license1>
Is there some way I can resolve this? I definitely did not have enough time to complete the evaluation.
There's a special forum for quicker response on licensing problems.
It looks like your license file isn't present in any of those folders (normally the one quoted in #3). If you don't have a copy of the license file (it should have been emailed to you) you should be able to go to https://registrationcenter.intel.com and request another. If you didn't register and create a support account, you can do it there, if you have your serial number.
Let me move this thread to the registration forum. there will be more experts help you.
thanks,
Jennifer
thanks,
Jennifer
