Software Archive
Read-only legacy content
17060 Discussions
Evaluation license error #10310: Failed to enable trusted storage check for licensing
Matthias_M_2
I just installed the Intel Visual Fortran Composer XE 2015 and have the problem described here: https://software.intel.com/en-us/articles/evaluation-license-error-10310-failed-to-enable-trusted-storage-check-for-licensing.
It would be great if you could send me an evaluation license file to get around the issue. In case you offer free full licenses for students, that would be even better!
Thank you very much,
Matthias
Feilong_H_Intel
Hi Matthias,
I sent the license file to you a few minutes ago.
CJ, please send me your email or serial number via Private Message.  I'll resend your license file as well.
CJ_Liu
I have the same problem with C++ compiler 64 bit for evaluating the Parallel Studio XE 2015. Can you, meaning the Intel tech support guy, also provide me an eval lincense please. Thanks! CJ
Feilong_H_Intel
Hi Matthias,
Matthias_M_2
Thanks!
