Software Archive
Read-only legacy content
17060 Discussions
Expected Vectorization with Array Notation
Jorge_Martinis
Hi There!
I have a large number number of loops written in Array Notation. After a build with options /O2 and /Qvec-report3 activated, I found that none of those loops were vectorized. I tried to find reasons in the documentation without success. What reasons would prevent the composer from vectorizing a loop in Array Notation?
Thanks!
Brandon_H_Intel
Hi Jorge,
Are you getting any output at all from /Qvec-report3? There might be a problem with your settings if you're not, which I can assist with. /Qvec-report3 should normally give you reasons why loops aren't vectorizing.
A complete listing of the compiler and linker options used and the compiler output you're seeing would be a good next step.
Jorge_Martinis
Hi Brandon,
I am afraid I cannot make our compiler options public. Could we move to a private thread? Once solved, we could share the solution (if any) with everyone.
Cheers,
Jorge
Jorge_Martinis
Brandon,
I found that all loops written using array notation were properly vectorized. The compiler reports them as:
...remark: FUSED LOOP WAS VECTORIZED
Thanks!
Jorge
Brandon_H_Intel
Jorge,
Glad to see there isn't a problem here, thanks for letting us know.
