We are just getting started with mpss and I was trying to follow the instructions found at http://software.intel.com/sites/default/files/article/373934/system-administration-for-the-intel-xeon-phi-coprocessor.pdf specifically the section on making an nfs export available to a coprocessor. "Implementation using CommonDir" page 23.
The documentation implies that /opt/intel/mic/filesystem/common should exist. It didn't so I created it and a directory etc under this. The document then wanted me to copy the existing fstab from mic0 to another location. Which makes perfect sense. But the problem is that for both of our co-processors the only skeleton file that seems to be available is /opt/intel/mic/filesystem/mic{0|1}/etc/sysconfig/network/ifcfg-mic0.
Have I missed something fundamental in our installation ? Any help would be appreciated.
I have seen that when runnig miccheck it complains that the running flash version is to low so I have been able to run
micflash -update -smcbootloader -device all and it appears to have completed successfully. I can not yet reboot the host to confirm this.
The system is CentOS 6.5 mpss 3.1.2
# service mpss status
mpss is running
]# miccheck
MicCheck 3.1.2-r1
Copyright 2013 Intel Corporation All Rights Reserved
Executing default tests for host
Test 0: Check number of devices the OS sees in the system ... pass
Test 1: Check mic driver is loaded ... pass
Test 2: Check number of devices driver sees in the system ... pass
Test 3: Check mpssd daemon is running ... pass
Executing default tests for device: 0
Test 4 (mic0): Check device is in online state and its postcode is FF ... pass
Test 5 (mic0): Check ras daemon is available in device ... pass
Test 6 (mic0): Check running flash version is correct ... fail
device flash version does not match, should be '390', it is '386'.
Executing default tests for device: 1
Test 7 (mic1): Check device is in online state and its postcode is FF ... pass
Test 8 (mic1): Check ras daemon is available in device ... pass
Test 9 (mic1): Check running flash version is correct ... fail
Status: FAIL
Failure: A device test failed
# micinfo
MicInfo Utility Log
Created Thu Mar 13 12:15:23 2014
System Info
HOST OS : Linux
OS Version : 2.6.32-431.5.1.el6.x86_64
Driver Version : 3.1.2-1
MPSS Version : 3.1.2
Host Physical Memory : 132110 MB
Device No: 0, Device Name: mic0
Version
Flash Version : 2.1.02.0386
SMC Firmware Version : 1.16.5078
SMC Boot Loader Version : 1.8.4326
uOS Version : 2.6.38.8+mpss3.1.2
Device Serial Number : ADKC34200076
Board
Vendor ID : 0x8086
Device ID : 0x2250
Subsystem ID : 0x2500
Coprocessor Stepping ID : 3
PCIe Width : x16
PCIe Speed : 5 GT/s
PCIe Max payload size : 256 bytes
PCIe Max read req size : 512 bytes
Coprocessor Model : 0x01
Coprocessor Model Ext : 0x00
Coprocessor Type : 0x00
Coprocessor Family : 0x0b
Coprocessor Family Ext : 0x00
Coprocessor Stepping : B1
Board SKU : B1PRQ-5110P/5120D
ECC Mode : Enabled
SMC HW Revision : Product 225W Passive CS
Cores
Total No of Active Cores : 60
Voltage : 1010000 uV
Frequency : 1052631 kHz
Thermal
Fan Speed Control : N/A
Fan RPM : N/A
Fan PWM : N/A
Die Temp : 34 C
GDDR
GDDR Vendor : Elpida
GDDR Version : 0x1
GDDR Density : 2048 Mb
GDDR Size : 7936 MB
GDDR Technology : GDDR5
GDDR Speed : 5.000000 GT/s
GDDR Frequency : 2500000 kHz
GDDR Voltage : 1501000 uV
Device No: 1, Device Name: mic1
Version
Device Serial Number : ADKC34200071
Board
Vendor ID : 0x8086
Device ID : 0x2250
PCIe Width : x16
PCIe Speed : 5 GT/s
ECC Mode : Enabled
Cores
Voltage : 968000 uV
Thermal
Fan RPM : N/A
Fan PWM : N/A
Die Temp : 42 C
GDDR
GDDR Version : 0x1
GDDR Size : 7936 MB
As a follow up to this. Problem resolved. The file locations in the document I was referencing weren't correct. As well that this fstab was already being copied as part of mic0.filelist and mic1.filelist so this was overriding common.filelist.
