Hello, I modified the C# example from the SDK in order to be able to select all the available colors for the example. There are several RGB options to select a 720 or 1080p Scan. However after selecting those options the "Init Failed" message appears and the 3D Scan is not working. Is this because of a HW restriction or program error?
Can somebody help me out to understand why is not working?
Maybe you should include the specification of hardware that you use.
I'm using Intel i5 5th Gen, with 16 Gb of RAM in a DELL computer. I'm using a F200 camera as well with DCM1.4 and latest SDK.
