Software Archive
Read-only legacy content
17061 Discussions
FFTW wrapper not available in offload mode
Nathanael_S_
We are trying to offload the main computations to the MIC, which includes FFT via the MKL and its fftw wrappers.
We are now running into this compilation error:
function "fftw_execute_dft" called in offload region must have been declared with compatible "target" attribute
Is this a bug, or is this intended ? Or do we link with the wrong library here ?
Any help appreciated.
Dmitry_B_Intel
It may help if you wrap [#include "fftw3.h"] between [#pragma offload_attribute(push) target(mic)] and [#pragma offload_attribute(pop)]
Nathanael_S_
Thank you for your suggestion. There is a typo in your answer, the correct pragma is [#pragma offload_attribute(push target(mic))].
Compilation now works, but at runtime I get this error:
On the remote process, dlopen() failed. The error message sent back from the sink is /tmp/coi_procs/1/6438/load_lib/iccoutNOEXQX: undefined symbol: fftw_execute_dft
offload error: cannot load library to the device 0 (error code 20)
On the sink, dlopen() returned NULL. The result of dlerror() is "/tmp/coi_procs/1/6438/load_lib/iccoutNOEXQX: undefined symbol: fftw_execute_dft"
Ravi_N_Intel
Did you use -mkl option on the command line.
Nathanael_S_
Using -mkl option solved the problem. Many thanks.
