Software Archive
Read-only legacy content
17060 Discussions
Facebook Connect App signature OR Key Hashes
Fab_V_
Hi guys,
i'm using intel xdk 1995 to build a professional app Android/IOS.
I use the Facebook connect plugin.
I'm facing a problem that my app does not have key hashes configured when trying to login with facebook.
After having searching a while on the internet it appears that the facebook app signature can not be obtained on intel xdk or appcenter.
I don't understand how to get this key to make my app work. I'm already using OPENFB alternative lib but the problem is that we always
have to enter login/password to connect with facebook because of web view login and not facebook app.
Could you tell me how to make it work ?
PS : i already sent an email to intel to get an app signature but i don't understand why not getting it directly ?
THX
Amrita_C_Intel
Hello Ven,
Are you using legacy build? or Cordova ? I would recommend using Cordova. And if you see this article there is a simple sample which could help you.
https://software.intel.com/en-us/xdk/article/facebook-connect-plugin-android-ios
regarding Key hash- We have received your request and will process it today. No reason to be upset :)
Marcio_G_
I'm using a Cordova plugin and follow this documentation: https://software.intel.com/en-us/xdk/article/facebook-connect-plugin-android-ios
I also need the Hash Key for my application, I sent an email to: html5tools@intel.com 5 days ago but I not received any return. To which email address should I ask?
PaulF_IntelCorp
That's the correct email address, I'll send a note to the folks that monitor that email address...
Amrita_C_Intel
Your keystore request has been emailed to you.
Amrita_C_Intel
Please see Hash key is the explicit value stored inside the keystore
Marcio_G_
I didn't received any email here in ...@ultrahaus.com.br that was I requested, or in the mail from my Intel account ..@bol.com.br. I checked including the SPAM boxes, can you send me again?
Amrita_C_Intel
Your HashKey request has been emailed to you.
Marcio_G_
I received by the .keystore file in e-mail with the alias and password. I follow the information in this link: https://developers.facebook.com/docs/android/getting-started#release-key-hash to get the key hash and link on Facebook.
But after that, I compile again, when I test using the Facebook login feature, it points that "Invalid key hash. The key hash ... does not mach any stored key hashes.".
When compiling, it is automatically linked the KeyStore or do I need to do something manually? Is there any documentation explaining the process?
Marcio_G_
I discovered the problem. I extracted the keyhash from the keystore you sended to me by email, but do not know if I did something wrong, because when I logged into Facebook from my app, Facebook's app indicated that the Hash was not beating.
But the Facebook app indicates what the Hash that the app is sending, I typed this direct in Facebook developer site and it worked.
Thanks!
