Software Archive
Read-only legacy content
Fail to active Depth and IR functionality
q_f_
With raw_streams.exe and others exe in SDK, images/color works properly. But the Depth and IR doesn't work. It start and then stop. You can see the attached log file from SDK_INFO and logs
q_f_
fixed. It's due to a bug in windows8.1 or intel usb3.0. All information says it's a USB 3.0 port but it works at USB2.0 speed. Uninstalling the driver and changing some settings about usb in bios make it work as usb 3.0 actually.
Machine Model: lenovo T440
samontab
Valued Contributor II
Make sure that you are using the intel realsense camera and the built in camera in your laptop.
q_f_
Yes, I've disabled the builtin camera and then uninstall the driver.But it doesn't work
Xusheng_L_Intel
Can you run this sample app @C:\Program Files (x86)\Intel\RSSDK\bin\win32\camera_viewer.exe? Thanks!
q_f_
q_f_
And thanks all the reply
Quentin_S_
What did you modified in your BIOS about USB settings ? I've some issues with the camera when plug/unplug it. It can be usefull to make a try too.
Thanks in advance.
Arun_D_
Hello q.f
I am facing the same problem i.e. RGB part is functioning but depth and IR isn't running.
please tell exactly what you did to resolve this issue.
q_f_
It's usb3.0 problem. try to reset usb driver/config may help
