Software Archive
Read-only legacy content
17060 Discussions
Fantastic configuration for media rendering
jayjay4u83
Hello Users , am using DP45 SG mobo with Quad prc, the rendering time is marvellous with the 2 GB DDR3 memory, which reduce the time consumption , Memory types for the Extreme series are 1333/1066 - DDR3 1600 Mhz- in the DP55KG, DP55SB makes a huge difference in speed but sometimes it hangs while rendering high end animation cliping,
After overclocking the performance is good but there is no room to let the heat out of the body , there should be an option for the cooling procedure in the heatsink for the better performance , this helps a lot in SLI , if the resolution is high,
when compared with the FSB of the DP45SG with the DX58SO the overal performance is amazing. this wil help a lot of difference in the essential series .
PPl pls help me with your input to enhance the performance .
