Software Archive
Read-only legacy content
Flash Light
zahid_s_
i am  trying to create a flash light but the code is not working. i am testing on iphone 4s. ios 9. i am using this script....
$(document).on("click", ".uib_w_3", function(evt)
        /* your code goes here */
            window.plugins.flashlight.available(function(isAvailable) {
              if (isAvailable) {
                  window.plugins.flashlight.toggle(function(){
                    alert("Success");
                  }, function(){
                    alert("Failure");
              } else {
                alert("Flashlight not available on this device");
kindly help me to resolve. Thanks in advance.
2 Solutions
PaulF_IntelCorp
How are you testing this? It will not work in App Preview (test tab) or in the Emulate tab, because you are using a third-party plugin. To test this on an iOS device you'll need to build the app and run it on a real device. For Android, you can use the Debug tab. See this doc page > https://software.intel.com/en-us/xdk/docs/intel-xdk-debug-and-test-overview
Elroy_A_Intel
I recommend submitting an issue request on the plugin developer's Github page . This plugin may have a limitation per device and operating systems.
PaulF_IntelCorp
Elroy_A_Intel
