I am trying to copy an array of the following structure to Xeon Phi (offload model in KNC)
type phys integer , dimension(:), allocatable :: arr1 end type phys
I found out in the following article -
https://software.intel.com/en-us/articles/asynchronous-data-transfer-and-computation (para 2 last statement)
that this is not supported. Is there some recent support? What are the alternatives except fixing the dimension of arr1.
Amlesh
Sorry, the document requires some updating. We will have it revised.
There is support in our current PSXE 2016 (16.0 compiler) release for offloading a derived-type with an allocatable component. The simple example below comes from another internal report related to this support.
program offload10 use mic_lib type my_derived_type integer :: i real :: r real, dimension(7) :: a real, dimension(:), allocatable :: b end type type(my_derived_type) :: s allocate(s%b(7)) s%i = 1 ; s%r = 2. ; s%a = 3. ; s%b = 4. num_dev = OFFLOAD_NUMBER_OF_DEVICES() write (0,'(a,i2)') 'Host :: Number of devices = ', num_dev write (0,*) write (0,'(a,1x,i4,1x,f5.2,/,7(f5.2,1x),/,7(f5.2,1x))') 'host', s%i, s%r, s%a, s%b write (0,*) !dir$ offload begin target (mic) in(s) in(s%b) write (0,'(a,1x,i4,1x,f5.2,/,7(f5.2,1x),/,7(f5.2,1x))') 'MIC ', s%i, s%r, s%a, s%b s%i = 2 ; s%r = 4. ; s%a = 6. ; s%b = 8. !dir$ end offload write (0,*) !dir$ offload begin target (mic) out(s%i, s%r, s%a, s%b) write (0,'(a,1x,i4,1x,f5.2,/,7(f5.2,1x),/,7(f5.2,1x))') 'MIC ', s%i, s%r, s%a, s%b !dir$ end offload write (0,*) write (0,'(a,1x,i4,1x,f5.2,/,7(f5.2,1x),/,7(f5.2,1x))') 'host', s%i, s%r, s%a, s%b write (0,*) end program
$ ifort -V Intel(R) Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 16.0.3.210 Build 20160415 Copyright (C) 1985-2016 Intel Corporation. All rights reserved. $ ifort DPD200361783.f90 $ ./a.out Host :: Number of devices = 2 host 1 2.00 3.00 3.00 3.00 3.00 3.00 3.00 3.00 4.00 4.00 4.00 4.00 4.00 4.00 4.00 MIC 1 2.00 3.00 3.00 3.00 3.00 3.00 3.00 3.00 4.00 4.00 4.00 4.00 4.00 4.00 4.00 MIC 2 4.00 6.00 6.00 6.00 6.00 6.00 6.00 6.00 8.00 8.00 8.00 8.00 8.00 8.00 8.00 host 2 4.00 6.00 6.00 6.00 6.00 6.00 6.00 6.00 8.00 8.00 8.00 8.00 8.00 8.00 8.00
Hi Kevin,
I think this issue is taken care of in version 15.0.2 also (i've this version and above code works on it).
Now please have a look at the following code -
program abcde
type phys
integer , dimension(:), allocatable :: phys_arr1
end type phys
type(phys) :: phys_array(2)
type(phys) :: phys_scalar
integer :: i, j
do i = 1,2
allocate(phys_array(i)%phys_arr1(16))
end do
allocate(phys_scalar%phys_arr1(16))
do i = 1,16
phys_scalar%phys_arr1(i) = i
end do
do i = 1,2
do j = 1,16
phys_array(i)%phys_arr1(j) = j
end do
end do
!dir$ offload begin target(mic:0) in(phys_scalar%phys_arr1, phys_array(1)%phys_arr1,phys_array(2)%phys_arr1)
print *,"Array 1 Mic is ",phys_array(1)%phys_arr1
print *,"Array 2 Mic is ",phys_array(2)%phys_arr1
print *,"Scalar Mic is ",phys_scalar
!dir$ end offload
end program abcde
In my system, it generates the following output -
[amlesh@node5 offloading]$ ifort -v
ifort version 15.0.2
[amlesh@node5 offloading]$ ifort abcde.f90
[amlesh@node5 offloading]$ ./a.out
[Offload] [MIC 0] [File] abcde.f90
[Offload] [MIC 0] [Line] 28
[Offload] [MIC 0] [Tag] Tag 0
Array 1 Mic is 1 2 3 4 5
6 7 8 9 10 11
12 13 14 15 16
Array 2 Mic is
Scalar Mic is 1 2 3 4 5
6 7 8 9 10 11
12 13 14 15 16
[Offload] [HOST] [Tag 0] [CPU Time] 0.016002(seconds)
[Offload] [MIC 0] [Tag 0] [MIC Time] 0.010511(seconds)
Please note the strange behavior for phys_array(2). (There's one more issue, when I change the order in which I specify sending the phys_arrays in the "in" clause, I get a segmentation fault).
Even if the above issue is taken care of, what about if the dimension of phys_array is say 800 (instead of 2) and there are some 20 allocatable arrays inside the derived type "phys". It would be impractical to specify everything in the "in/inout" clause. (this is the case with the application I am working on, above is just a dummy code). Please suggest possible software solutions, if available.
Amlesh
General expressions such as phys_array(1)%phys_arr1 are not supported in the offload directives.
The compiler not issuing a diagnostic is a bug.
In your example, what you've written as phys_scalar, *is* supported.
Thank you Rajiv for the clarification. I escalated the non-diagnostic to Development.
(Internal tracking id: DPD200412581)
