Software Archive
Read-only legacy content
17060 Discussions
Framework7 Material Pre-Loader
Mitchell_Franklin
Hi All,
Currently using the latest release 3400 and have noticed that for framework7 the pre-loader for the material theme is not displaying the loading indicator.
I have tested this via the emulator and build with the same results, is it possible to ask for this to be looked into?
Mitch
Material:
IOS: (Working)
Framework7 site:
Pamela_H_Intel
Absolutely, Mitch. I will forward this issue to the developer in charge of that. Thanks for including images, that helps tons!
. . . Mitch - I see that this is a known issue and is planned to be fixed in the next release of XDK.
Pamela
Mitchell_Franklin
Thanks Pamela, greatly appreciated as always
Mitchell_Franklin
Hi Pamela,
Thought I would wait a bit with the bugs of the new version being updated and have just checked the latest release now and can see the preloader for the Material Theme Framework7 still not appearing, would this still be able to be looked into? and would you have an idea on a work around?
Note: Just to make sure I created a new project in the current version to check this.
Ta
Mitch
PaulF_IntelCorp
Hi Mitch -- your issue was filed, but no action has been taken on your issue. The issue that Pamela referred to as being addressed in the next release was, in fact, a different issue (that looked similar to yours, but is not the same).  :-(  I've requested some follow-up from the responsible engineer.
