Software Archive
Read-only legacy content
17060 Discussions
Framework7 & Material Theme (BUG?)
Andrejs_V_
I start clean new project with Appdesigner  and Fr7
If I check Material design and AFTER add header (for example ) I get this strange view in designer (see attach file)
I index.html I see that lines
<link rel="stylesheet" type="text/css" href="framework7/css/framework7.ios.colors.min.css">
<link rel="stylesheet" type="text/css" href="framework7/css/framework7.material.min.css" class="uib-framework-theme">
<link rel="stylesheet" type="text/css" href="framework7/css/framework7.ios.min.css" class="uib-framework-theme">
after manually changing to
<link rel="stylesheet" type="text/css" href="framework7/css/framework7.material.colors.min.css">
all start working ...
Is it BUG, or I need add any widget to form and AFTER them change theme to material?
Andrejs_V_
oops
there missed attach
PaulF_IntelCorp
I've asked one of my more knowledgeable colleagues to chime in.
Brian_W_Intel
This is a bug. The colors .css should be added in alongside the other theme css. I'll add this fix into the next release.
