Software Archive
Read-only legacy content
17060 Discussions
Framework7 side panel can't close when tap on outside
Arthur_T_
Step to repeat:
- create a new project as Standard HTML5 application using App Designer and Framework7
- create 2 buttons, 1 left sidebar by drag the control on the page
- 1 button will open left sidebar, 1 button will prompt an alert
After I build the app and deploy to iPhone, it can open the left sidebar by click on the button. But can't default close it when tap outside the sidebar. Instead, it handle my tap on button script too so the alert prompt when I tap on the button. No different for
var myApp = new Framework7({
   panelsCloseByOutside: true
Anything wrong?
P.S. I'm using Intel XDK ver3240 run on iMac OSX El Capitan. iPhone 6s
Elroy_A_Intel
This seems to be an issue in regards to the functionality of the framework and the App Designer tool. I have escalated this issue to the App Designer engineering team.
Brian_W_Intel
If you add the following as a direct child of the body tag, you should achieve the functionality you want:
<div class="panel-overlay"></div>
Arthur_T_
Thanks Brian, it works. So it is XDK issue as missing that code.
Chris_P_Intel
We have a feature planned for the future so that users of F7 can elect the overlay or not. Presently, it is not included and users must add it manually.
Arthur_T_
Understood, thanks Chris.
Andrejs_V_
It is a little error in XDK
for F7 You should add class "close-panel" for closing panel element , example - button on slide panel
