Software Archive
Read-only legacy content
17060 Discussions
Function Pointers
Intel_C_Intel
Several Windows API's require the address of a function (MyFunc, say) as input. As far as I can make out, the rules-of-behavior of CVF's (%)Loc extension in conjunction with use of integer (Cray-style) pointers prohibit passing the address of MyFunc. The only way around that I can conjur up is that if MyFunc is in a MyDLL then its address is GetProcAddress(LoadLibrary('MyDLL'C),'MyFunc'C) assuming MyFunc is an export. But if I don't want to export MyFunc, what's my alternative? Does F2K's interoperability-with-C impact on what I'm trying to do?
Gerry T.
Jugoslav_Dujic
Valued Contributor II
Not 100% sure to me what you're trying to do. Nothing prohibits
you from using LOC() on an existing function, for example
when subclassing a window:
lpfnOldWindowProc=SetWindowLong(hWnd, GWL_WNDPROC, LOC(MyWindowProc))
If your function is pointee of an integer-pointer, simply pass
the integer pointer once it receives a valid value. Thus, you don't
need mesing with DLLs.
Or am I missing something?
Jugoslav
Right - as long as CVF knows it's a procedure (either there's an INTERFACE or an EXTERNAL declaration), you can pass LOC(routine), if the argument is declared as an integer. If the Fortran INTERFACE declared the argument as a procedure, then pass the procedure name directly (not an issue with Win32 API routines).
Steve
Intel_C_Intel
Did you try this? Surely LOC(MyWindowProc) is the name of an internal procedure which (%)LOC doesn't allow?
Gerry T.
Intel_C_Intel
I want to call SetConsoleCtrlHandler as interfaced in kernel32.
the code snippet
interface
subroutine SetCtrlHandler(hConOut)
integer hConOut
end subroutine SetCtrlHandler
end interface
call SetCtrlHandler(hwnd)
logical(4) function handler(dwCtrlType)
!Success
handler = 1
return
end function handler
use dfwinty
use kernel32, only: SetConsoleCtrlHandler
implicit none
interface
logical(4) function MyHandler(hConOut)
integer hConOut
end function MyHandler
end interface
external handler
pointer(ptr_handler,MyHandler)
integer hConOut
logical(4) status
integer, external :: MyHandler
ptr_handler = Loc(handler)
status = SetConsoleCtrlHandler(Myhandler,.true.)
the equivalent code snippet is
interface
subroutine SetCtrlHandler[C,ALIAS:'_SetCtrlHandler'] (hConOut)
integer hConOut
end interface
#include
#include
#include
BOOL WINAPI handler(DWORD dwCtrlType)
	return(TRUE);
void SetCtrlHandler(HANDLE hConOut)
  BOOL status;
  //Set custom handler for process
  status = SetConsoleCtrlHandler(handler, TRUE);
  return;
This Fortran/C version works (and so does the handler) but the all Fortran version doesn't even compile due to 1 or 2 errors, viz:
1. at the statement
Error: This name has already been used as an external procedure name. [MYHANDLER]
2. at the statement
Error: This actual argument must not be the name of a procedure. [MYHANDLER]
If I remove the interface to MyHandler, the first error goes away and the secord error changes to
Can someone kindly tell me what's wrong with the all Fortran version?
Gerry T.
The interface block defines MyHandler, so your EXTERNAL declaration is redundant. Remove it. Use loc(MyHandler) in the call to SetConsoleCtrlHandler.
Warning - this code may not work correctly unless you compile with /fpscomp:logicals. CVF LOGICAL is not the same as C BOOLEAN, which is what the Win32 API uses. I suggest making MyHandler INTEGER instead of LOGICAL and passing TRUE (from DFWINTY) instead of .TRUE. - these are different values.
Steve
Intel_C_Intel
Excellent. Thanks Steve and Jugoslav. Now the all Fortran version works and so does the handler.
Ciao,
Gerry T.
