Software Archive
Read-only legacy content
17061 Discussions
G965 - World in Conflict
pimpware
Hi to all
I have a P5B-VM MBoard with a integrated G965 X3000 graphic card.
CPU : Q6600
RAM : 1Gb
I've tried to play the game World in Conflict and after the video intro it just crash, BSOD with something about graphical driver, I just updated it but no effect.
At first I thought it was because of shared mem, I only have 1 Gb ...
But I just read somewhere on internet that this game is unsupported for this graphic card.
I just tried it on a old celeron 2.6 with a Radeon 9600 and works fine.
bikerfoo
Well looking over the WOC support page I didn't see anything saying Intel graphics were not supported. What version of DirectX is on your system? Also, what OS you running?
pimpware
Windows XP pro
DX 9.0c
Both computers have the same windows and DX versions.
I found one board with someone with the same problem, and there is another one, I can't find it now, I found it at some google search ...
http://forums.anandtech.com/messageview.aspx?catid=31&threadid=1934968&enterthread=y&STARTPAGE=3
The other place I can remember that a guy was saying about unsupported pixel shadding or something like that.
bikerfoo
I don't have the game but I have a G965 based system. I went to canyourunit.com and according to the analisys ran on my system the game should run.
pimpware
According to canyourunit.com I should play it wit no problems...
I just uninstalled and installed again the graphic drivers, but I can only get BSOD.
Can it be low mem ?
I have 1Gb Ram, shared with graphic card and the windows load ...
elghali
mir ci
bikerfoo
Not sure it's low mem. 1GB is a sweet spot for XP. What are your DVMT settings in BIOS? Can you post up the Information Report from the graphics driver CUI?
pimpware
It was set to DVMT mode 256Mb, changed it to Fixed mode 256Mb, but didn't notice any change.
Where can I get the Information Report ?
bikerfoo
Right click on desktop , click "Graphics Properties", click "Information" button, click "Save to File".
pimpware
Intel Graphics Media Accelerator Driver Report
Report Date: 09/27/2007
Report Time[hr:mm:ss]: 19:51:11
Driver Version: 6.14.10.4864
Operating System: Windows XP* Professional, Service Pack 2 (5.1.2600)
Default Language: English
DirectX* Version: 9.0
Physical Memory: 1007 MB
Minimum Graphics Memory: 8 MB
Maximum Graphics Memory: 256 MB
Graphics Memory in Use: 12 MB
Processor: x86 family 6 Model 15 Stepping 11
Processor Speed: 2400 MHZ
Vendor ID: 8086
Device ID: 29A2
Device Revision: 02
* Accelerator Information *
Accelerator in Use: Intel G965 Express Chipset Family
Video BIOS: 1348
Current Graphics Mode: 1280 by 1024 True Color (75 Hz)
* Devices Connected to the Graphics Accelerator *
Active Monitors: 1
* Monitor *
Monitor Name: Plug and Play Monitor
Display Type: Analog
Gamma Value: 2.20
DDC2 Protocol: Supported
Maximum Image Size: Horizontal: 13.0 inches
Vertical: 10.0 inches
Monitor Supported Modes:
640 by 480 (60 Hz)
640 by 480 (67 Hz)
640 by 480 (72 Hz)
640 by 480 (75 Hz)
720 by 400 (70 Hz)
800 by 600 (56 Hz)
800 by 600 (60 Hz)
800 by 600 (72 Hz)
800 by 600 (72 Hz)
800 by 600 (75 Hz)
832 by 624 (75 Hz)
1024 by 768 (60 Hz)
1024 by 768 (66 Hz)
1024 by 768 (66 Hz)
1024 by 768 (70 Hz)
1024 by 768 (70 Hz)
1024 by 768 (75 Hz)
1152 by 864 (75 Hz)
1152 by 870 (75 Hz)
1280 by 960 (60 Hz)
1280 by 1024 (60 Hz)
1280 by 1024 (70 Hz)
1280 by 1024 (75 Hz)
Display Power Management Support:
Standby Mode: Supported
Suspend Mode: Supported
Active Off Mode: Supported
Raw EDID:
00 ff ff ff ff ff ff 00 3a ac 00 00 00 00 00 00
01 10 01 03 6c 22 1b 78 ea fd 06 a3 5b 4a 98 26
1f 4f 54 bf ef 80 81 80 81 8a 71 4f 61 46 61 4a
45 4c 81 40 61 46 30 2a 00 98 51 00 2a 40 30 70
13 00 52 0e 11 00 00 1e 00 00 00 fd 00 32 4b 18
50 0e 00 0a 20 20 20 20 20 20 00 00 00 fc 00 31
37 27 27 0a 20 20 20 20 20 20 20 20 00 00 00 fc
00 20 0a 20 20 20 20 20 20 20 20 20 20 20 00 05
* Other names and brands are the property of their respective owners.
bikerfoo
Everything looks to be in order. If I had the game I would give it a try to see if it worked on my system. Do you have access to any other memory sticks? Try swapping out the memory. Your not over clocking anything are you?
davidc1
The Vista driver 15.6 will run World in Conflict. It's not the game's fault. 14.31.1 driver is overall better than 15.6 driver but its still not perfect. There is more work for Intel driver engineers to do.
