Hi everybody.
I have IoT devix image installed in my Galileo and I would like to transfer images from my computer (macbook) to Galileo (root folder for example) by internet, because the Galileo is in the lab and I want to work at home. As I use a macbook, the SSH connection is made by the terminal in mac. I see that in Windows System the SSH platform comes already with an interface that helps us to do the file transfer.
Thank you.
- Tags:
- Internet of Things
In Windows you can use Putty to connect over ssh and for transfer WinSCP would help.
on Linux e.g. (probably similarly on MacOS)
- scp
- sshfs mount Galileo filesystem
- sftp
- on sender side: "cat <file> | nc <ip Galileo> -p <port>"; on Galileo side: "nc -l <port> > <file>" [not 100% sure whether nc -l is supported out of the box on Galileo]
select your favorit :-) [if I do have to work on a lot of files on Galileo or Edison I tend to sshfs mount the target. That way I can access the target files just like on my host just with more latency]
![](/skins/images/BC9A7A3465121B56B278007F4EE8899F/responsive_peak/images/icon_anonymous_message.png)
