Software Archive
Read-only legacy content
17060 Discussions
Gearpump Java Examples
Raheem_D_
I am trying to get the gearpump java examples, (2.11.5-0.6.1.4), to work.  Has anyone had any luck building them.  So far, I have figured out I need to:
1.  Build the gearpump-shaded-repo project
2.  Tried building the java example as is and deploying.  Got some class not found errors
3.  Tried building a shaded jar out of the java examples, but got an NPE
Anyone had any luck?
Thanks!
steve_m_1
This repository holds some common gearpump usage patterns with Java.
The examples include:
word count -- simple Java app that shows the structure of gearpump app
Kafka -> Kafka pipeline -- very simple example that shows how to read and write from Kafka topics
Kafka -> HBase pipeline -- how to read from Kafka topic, how to write to HBase
To build the examples run:
mvn package
After build, there is a jar under target/streaming-java-template-$VERSION.jar.
Start the gearpump cluster (0.4)
a) Download from http://www.gearpump.io/site/downloads/
b) After extraction, start the local cluster
bin/local
c) Start the UI server
bin/services
Submit the jar
bin/gear app -jar path/to/streaming-java-template-$VERSION.jar <app mainclass with package>
for example:
bin/gear app -jar target/streaming-java-template-$VERSION.jar javatemplate.WordCount
Check the UI http://127.0.0.1:8090/
NOTE:
Please use Java7 to run the cluster.
You can set the ENV JAVA_HOME.
On windows: set JAVA_HOME={path_to_java_7}
On Linux export JAVA_HOME={path_to_java_7}
