Software Archive
Read-only legacy content
17060 Discussions
Get the Power Consumption Info When Running a Program
Jiawen_L_
When I run a program using offload mode, I want to collect the information of power consumption of the MIC. Is there any way to do that?
I found that I can use the micsmc to get the Total Power info in the command line/GUI interface.(https://software.intel.com/en-us/blogs/2014/01/31/intel-xeon-phi-coprocessor-power-management-configuration-using-the-micsmc-command) Could I add a function from any libraries inside a program to collect the power consumption when use offload mode?
Jiawen
JJK
New Contributor III
this question has come up on this forum a few times already. Search the forum for 'power consumption" and you will find similar posts, e.g.
  https://software.intel.com/en-us/forums/intel-many-integrated-core/topic/596030
