Software Archive
Read-only legacy content
17060 Discussions
How device differentiate between 2 different applications
Amr_S_
Hi
I have built 2 applications with intel XDK with different names and splash screens but i didn't edited any other details
but
when i tried to download APKs on my mobile , the mobile considered the second application as an update to the first one
so how could i make them different 2 applications ? what to edit in Intel XDK to make like that ?
Eduardo_C_Intel
Amr, make sure you change the application package as well. If it is an Android device, android will use the application package to identify your application, if you have one with the same package it will try to re-install it.
Anusha_M_Intel1
In build settings, under the platform that you are building for - change appName and appID.
Amrita_C_Intel
If you are building for the same platform more than once change the appID each time before you build. Appname can be same.
Amr_S_
ok i will try that  , but where could i find that application package inside the XDK ?
Amr_S_
Anusha M. (Intel) , Amrita C. (Intel)
I tried before to change the app name but it is also consider it as an update
but
i'll try to change the appID
Thanks a lot )
