Software Archive
Read-only legacy content
17060 Discussions
Getting Tmp error on creating project
Aftab_K_
I really appreciate someone can help me on my issue. First time I have successfully installed the XDK on my windows XP and when I try to create a project, it asks to enter the name and location. After I enter a location, it gives this error first:
intel xdk error: error creating tmp directory
My environment or TMP looks like this:
TEMP=C:\Users\Aftxxxx\AppData\Local\Temp;c:\mingw\bin
TMP=C:\Users\Aftxxxx\AppData\Local\Temp
I have logged in as admin and installed as admin. Thanks
PaulF_IntelCorp
The XDK does not run properly on Window XP, it is only validated for Windows 7 and above. If you need to use a Windows XP machine you can run Linux inside a virtual machine and install the Linux version in that virtual machine. Sorry, but XP is not supported and has been shown to fail.
Aftab_K_
OK Thank you so much for your quick reply. I try on Ubonto and hope it will work.
On a second note, can you point me to a working example of an app that works with remote database like mysql and display the data? Regards,
PaulF_IntelCorp
We don't have such an example, search for any PhoneGap or Cordova example. The XDK and PhoneGap create Cordova apps, so any sample you can find that works with those systems should work with the XDK.
