Software Archive
Read-only legacy content
17061 Discussions
Google Play: Certificate is diferent os previous version
Hamilton_Tenório_da_
Valued Contributor I
I have an App published in Google Play (several versions, since 07/2014) using Android version.
Now, I prepared a new version build with Cordova Croswalk. When I try publish this, I receive a error of certificate:
I always use the option Signed (Android and now Cordova Crosswalk Android).
What I need to do?
Francesc_S_
Perhaps this article will help you.
http://qnimate.com/signing-android-app-in-intel-xdk/
Another article in Spanish:
http://www.pepfarinblog.com/clave-de-android-para-phonegap-build/
You can not lose the certificate because, as you happen, you can not update the application. It must be the same for all new versions.
Thank you for the post.
I don´t know if it is a solution for me. I don´t have alias_name, key_file_name and my_application names. I never get these information. Always XDK signed for me.
Francesc_S_
Here is all the information about signing apps:
http://developer.android.com/tools/publishing/app-signing.html
Chances are that when you switch to Crosswalk Android has generated a new key, so do not match, and can not update the app. I have no idea how it could be solved.  :(
I thing the problem is other. I made some others APP, first Android, and then Cordova, and all of them were published without problem. I think that is a temporary problem in the build. I am waiting Intel see it.
Thank you again.
John_H_Intel2
If you originally published an app you made outside of the XDK, you used a different cert. If you want to use that same cert for your XDK account, you will need to contact us at html5tools@intel.com and we can help you there.
John,
I always used XDK. But, remember now, I had 2 accounts. Intel merge them... This can be the cause of the issue.
I wrote just now to html5tools@intel.com explaining this situation.
Thank you.
