Software Archive
Read-only legacy content
17060 Discussions
Graphics Quickwin Colors don't seem bright
Intel_C_Intel
I wrote some graphics with quickwin. The lines are okay. But they seem faint. I read some graphics books in Visual C++ and they have singleline, double line and tripleline. I think this would make my lines look bolder. How do I access these commands. Or am I doing something else wrong?
Rudy
david_jones
You can try using subroutine REMAPALLPALETTERGB to set up the required colours. However, use colour names from the following list
$LOBLACK ,$LOBLUE , $LOGREEN , $LOCYAN , $LORED , $LOMAGENTA
$LOBROWN ,$LOWHITE, $LOGRAY, $HIBLUE, $HIGREEN, $HICYAN
$HIRED, $HIMAGENTA , $HIYELLOW, $HIWHITE
rather than the names in the on-line help. These should also work for SETCOLORRGB.
David Jones
Intel_C_Intel
I am trying to use remappalletergb. My call always return not zero. I notice that the syntax or example has an error for the declaration size of status *4 or *2 and indes *4 or *2. But I tried both and this doesn't seem to be the issue. I tried to set indexs from 18 to 31. While 18 19 and 20 may not be changeable, the rest should be changeable. I plot these color indices as blank. So the color at the specified index is not being set. What do you think I am doing wrong.
Intel_C_Intel
I have setcolorrgb working. It seems to create a color every time I need one. I would still prefer to change the whole palette then index the color. Any ideas?
Rudy
david_jones
I use the approach of setting all the colours required using remappalettergb, for example using ...
IDUM=remappalettergb(int2(1),$hiwhite)
I use commands like these to replace the default settings for the indices 1,2,... . Then after this these once and for all settings, I use commands like ..
IDUM=SETCOLOR(ICol)
to change the current plotting colour to that for index ICol.
