Software Archive
Read-only legacy content
17061 Discussions
Gui calls other GUI
hbe12
Can someone kindly help me with coding this? I have a GUI that open a file and read data from this file. then in this GUI there are three buttons, Add, Delete and Edit , When I click on edit another GUI show up which to edit some data, after I finish with the second GUI and clicking Ok, I am suppose to return to the first GUI, but the first is not showing up?
I would appreciate if you show me how to call a second GUI and keeping the first one visible as soon as finishing with GUI2.
Thanks in advance
Jugoslav_Dujic
Valued Contributor II
What do you mean a GUI? A dialog? If so, my guess is that you're reusing your DIALOG variable for two dialogs, i.e. that you have something like:
SUBROUTINE OnButtonEdit(Dlg, ID, iEvent)
USE DFLOGM
TYPE(DIALOG):: Dlg
iStatus = DlgInit(IDD_CHILD_EDIT, Dlg)
iStatus = DlgModal(Dlg)
If that's the case -- you mustn't do that. Variable Dlg you get through arg-list refers to the parent dialog and you're corrupting it. You have to declare another variable of type DIALOG and use that.
Jugoslav
