Software Archive
Read-only legacy content
17060 Discussions
HAXM installation error - again
Peter_T_1
Sorry for this again, but after reading all HAXM installations issues, I still can not install mine (hence can not run emulator). It says the XD bit is not enabled. I have checked it is enabled by windows and ran the bcdedit just in case.
I'm using Win7SP1 32bit, Intel Core2Duo T8300, XD and VT-x features both enabled in BIOS, no virtualization software installed (checked events HyperV is not there). I'm trying to run API 19 emulator. T
Any ideas?
I appreciate every bit of help.
Peter
Colleen_C_Intel
The failing call seems to be CheckHAXStatusDeferred.   However on first call it returns value 1.
But failure is later when it's called again and returns value 3
     CheckHAXStatus: Looking for existing reboot marker: C:\Users\peti\AppData\Local\Temp\{5657796F-9AA4-41D7-93A1-0D95CF6CEFE8}_reboot_required.  (and gives XD not on and 1603 errors)
 So I would strong suggest doing an uninstall, and then checking that everything is gone in
     \users\<yourlogin>\AppData\Local\Temp    files of your install date but be sure to check for
 I'd also delete anything left in \Program Files\Intel\HAXM\ and Program Files\Intel\Download\HAXM\
and C:\Windows\Installer\MSIE4E4.tmp and MSIE591.tmp, MSIE65D.tmp,and 39e3f9.msi (per your log)
plus you might want to clean the drvstore of the sys/inf files
C:\Windows\system32\DRVSTORE\intelhaxm_BF70A650288CBA62C7469DB89BD275C624031117\IntelHaxm.sys' & inf
And I'd search the registry after the uninstall for HAX, but specifically check
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\F69775654AA97D14391AD059FCC6FE8E\
and there are probably at least 6 IDs under  HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\(multiple IDs)\ all with the key F69775654AA97D14391AD059FCC6FE8E
Then reboot and try to reinstall.
Alexander_W_Intel
can you download and run CPUID from the following URL:
http://crystalmark.info/software/CrystalCPUID/index-e.html
and post a screenshot here?
Thanks, Alex
Peter_T_1
Hi Alex,
I don't have my computer at hand now, but I have run CPU-Z and Intel Processor Identification utility. Both showed VT-x insturction set and Intel utility also showed XD bit.
I'll also post the picture later.
Cheers,
Peter
Peter_T_1
Hi Alex,
Here is the screenshot.
Cheers,
Peter
Alexander_W_Intel
Hi Peter,
It should work. Let me ask some colleagues if they have an idea...
Thanks, Alex
Colleen_C_Intel
Just checking - your bcdedit does show it as AlwaysOn  and  Windows (My Computer->Advanced System Settings->Advanced (tab)->Performance (settings button)->Data Execution Prevention ) shows it as on for all programs?
Peter_T_1
Hi Colleen,
Yes, I did check bcdedit based on the previous posts, along with Data Execution Prevention tab, both says AlwaysOn and on for all.
Cheers,
Peter
Colleen_C_Intel
can you send the haxm_install_log.txt file - should be in \users\<yourlogin>\appdata\local
Peter_T_1
Please see it attached.
Colleen_C_Intel
I find an error code 1603 which is often an MSI package error or putting the package entries into the registry.  I also see CustomAction CheckHAXStatusDeferred returned actual error code 1603 (note this may not be 100% accurate if translation happened inside sandbox).
The log also indicates the ND and VT settings are c
orrect, also indicating that the error message may be wrong. May I ask if you've tried a reboot and then reinstall?
Colleen_C_Intel
Peter_T_1
Hi Colleen,
Yes, I did try restarting&reinstalling before. It didn't help.
I'll try your suggestions (going to take some time to get back on that).
Peter
Peter_T_1
Hi Colleen,
I finally had time to deal with it.
I've double checked all of your references and they were not there. After a couple of restarts the installation seemed to succeed. Weird, but it work now.
Peter
Colleen_C_Intel
Glad to hear you got it working.
