I have an Intel i5-3570K @ 3.4GHz and an Asus P8Z77-V LK motherboard with 16GB of RAM. The Intel Processor Identification Utility reports:
Execute Disable Bit: Yes
Intel(R) Virtualization Technology: Yes
In the BIOS I have Intel Virtualization and Execute-Disable Bit Capability enabled and I am running the BIOS version 0403.
The message I am getting is:
'This computer meets the requirements for HAXM, but Intel Virtualization (VT-x) is not turned on. HAXM cannot be installed until VT-x is enabled. Please refer to the Intel HAXM documentation for more information.'
The first time I attempted the installation Intel Virtualization was not turned on. I have enabled it in the BIOS, shut the system down for 10 minutes with power removed, and reattempted the installation several times with the same error message.
I have attached the HAXM install log and the complete Processor Identification Utility report.
I'm at a loss where to go next.
- Tags:
- Android* OS
I had the same problem with a similar processor, core i5 m430, in my HP laptop. VT was also enabled on the BIOS and the problem was fixed when I uninstalled the avast anti-virus(no disabling the protection) and so I could finish the HAMX installation. After that, I installed the Avast software again.
I hope this issue can help more people.
- « Previous
- 1
- 2
- Next »
Nice
Error Message from Intel Hardware Accelerated Execution Manager Setup :
" Failed to configure driver: unknown error. Failed to open driver. "
My computer is :
Windows 7 Pro SP1
Processeur: Intel(R) Core(TM) i3-4030U CPU @ 1.90GHz 1.90 Ghz
RAM : 4,00 Go
64 bits
Audit from computer :
CMD -> bcdedit /set nx AlwaysOn
work
CMD -> bcdedit /set hypervisorlaunchtype off
work
CMD -> sc query intelhaxm
don't work
CMD -> Bcdedit -set TESTSIGNING ON
work
work
log is join
Intel Processor Identification join
Can you help me ?
Thanks!
Olivier L. FRANCE
Even if you have enabled the Virtualization(VT) in BIOS settings, some antivirus options prevent HAXM installation.
If you have antivirus e.g Avast Go into its settings and turn it off for a suitable period of time.
and then start installation again . I hope that this will work.
Best .
Haroon
I have enabled the Virtualization(VT) in BIOS settings.
I don't have antivirus on the PC.
but update intel are block.
Thx Harron for your response.
How can i do ?
Best .
Olivier
I find my problem.
The Proxy stop C:\Users\olouet\AppData\Local\Android\sdk\extras\intel\Hardware_Accelerated_Execution_Manager\intelhaxm-android.exe
now it s work.
Intel update is a other problem.
Thx,
Olivier
- « Previous
- 1
- 2
- Next »
