I found a nice example of playing an AVI clip in a dialog box on the MSDN/Visual Studio/ cd rom. It is a C program , animate.c, which I want to convert to a Fortran version using the GENERIC example as a basis.
I have got as far as getting the dialog box to open ok. I now find that I am unable to satisfy references to the WIndows macros ANIMATE_OPEN, ANIMATE_PLAY, ANIMATE_SEEK etc. From the infoviewer, I am referred to COMMCTRL.H as the place to find them. I do not have Visual C on my machine. Can anyone please point me to where they might exist within the Visual Fortran resources? TIA
链接已复制
5 回复数
Most of "helper macros" are not implemented by Compaq. "Helper macros" are actually various wrappers for SendMessage intended to make code more readable. So, you could either use SendMessage instead (with ACM_OPEN, ACM_PLAY, ACM_SEEK) or write your own wrappers.
Jugoslav
Jugoslav
Yes, thanks Jugoslav. I downloaded the SDK and found the macros in COMMCTRL.H and figured out the SendMessage
link. However, When I used Resource Editor to include an animation control in the dialog box, the dialog refuses to load
(DialogBoxParam returns -1). If I replace it with another control,such as an edit box, the dialog loads OK.
Any Ideas?
The resource script created for the control is as follows:
ANIMATEDLG DIALOG DISCARDABLE 50, 50, 304, 146
STYLE DS_MODALFRAME | WS_POPUP | WS_VISIBLE | WS_CAPTION | WS_SYSMENU
CAPTION "Animation Demo"
FONT 8, "MS Sans Serif"
BEGIN
DEFPUSHBUTTON "Quit",IDOK,223,122,50,14
PUSHBUTTON "Play",IDC_PLAY,22,122,49,14
PUSHBUTTON "Stop",IDC_STOP,89,122,49,14
PUSHBUTTON "Seek",IDC_SEEK,156,122,49,14
CONTROL "Animate1",IDC_EDIT1,"SysAnimate32",ACS_CENTER |
WS_BORDER | WS_TABSTOP,18,7,266,102
END
Any Ideas?
Many thanks again, Jugoslav, for your tip which worked.
I added the following to WinMain:
and added comctl32.lib to the library search step in the project Link settings
(I added Fullapi.f90 to the project, but that is missing comctl32.lib - maybe I will add
the appropriate !dec$objcomment lib:"comctl32.lib" comment to it for future reference). Again, many thanks.
interface subroutine InitCommonControls () !DEC$ IF DEFINED(_X86_) !DEC$ ATTRIBUTES STDCALL, ALIAS : '_InitCommonControls@0' :: InitCommonControls !DEC$ ELSE !DEC$ ATTRIBUTES STDCALL, ALIAS : 'InitCommonControls' :: InitCommonControls !DEC$ ENDIF end subroutine InitCommonControls end interface call InitCommonControls()
By the way Jugoslav, while programming in a call to GetOpenFileNAme to select files to be played in the animation control, I have discovered GetOpenFilenamePreview which, when
set up with an .AVI filter opens a preview pane in the Explorer dialog. It has succeded in previewing/playing every .AVI file I found on my PC, wheras only three of them were playable in the animate control.
