I would recommend:
1. Try to install Intel VGA driver from www.acer.com support site. If it will not fix the problem please:
2. Try to install latest Intel GMA driver from Intel Download Center http://downloadcenter.intel.com/default.aspx?iid=subhdr+downloads. Please choose the proper driver for your graphics chipset from the list on the site.
Philipp
Hopefully Philipp's recommendations worked for you. Please respond to let us know if this helped or not.
Note that I've also changed the title to be more descriptive and moved this thread to a better forum for handling general questions regarding graphics configuration and graphics drivers, the User Community for Visual Computing -- the original forum you posted your question to is for users of the Intel Graphics Performance Analyzers software toolset.
Neal
I could not get any solution for this problem...i got to hear that Intel Graphic Media Accelerator Driver version v15.10.1473 solves the problem when loaded with Vista64bit .....but unable to get v15.10.1473 drivers ... ? Pls let me know where i culd get this
Hi Vishnu,
Since you have mentioned that you are using XP OS, hence even if you find v15.10.1473 driver I am afraid it wont be of much use since it wont get install on XP OS.
With your earlier problem description it sounds like when you are trying to run Maya app your system throws some fatal error msg. It sounds like a Gfx driver issue. Can you please let us know what's exactly is that error msg? Does it cause hang or crash?
