Software Archive
Read-only legacy content
17060 Discussions
How can I use Face tracking module with R200 placed vertically?
zhao_x_
Can I rotate the raw stream 90 before feed to face tracking module?  But I can not find any code or function to do that in sdk manual or samples. Thanks!
Xusheng_L_Intel
You can rotate the image during AcquireAccess. The API will be
pxcStatus AcquireAccess(Access access, PixelFormat format, Rotation rotation, Option options, ImageData *data);
Please find detail @https://software.intel.com/sites/landingpage/realsense/camera-sdk/v1.1/documentation/html/acquireaccess_pxcimage.html?zoom_highlightsub=AcquireAccess
Thanks!
zhao_x_
Thanks! I can get the rotated image data now.
Then, How can I feed the rotated image to face tracking module? Should I do any thing before call "(PXCFaceData*) output ->Update();"?
Keith_B_1
I was just wondering this as well. Is it possible to track a face after rotating the image? Thanks to both of you!
Wei-chieh_H_
hello, after I rotate image, I meet the problom. coloBitmap.Dispose(); nullreferenceException. How can I solve?
hape
Hi Zhao X.,
feeding the face module with "modified" images is indeed possible. However, I doubt you can feed them directly in the rotated form - I suppose that the face module depends on the dimensions of the image. But this should not be to hard to be solved with some after-processing.
You need to obtain an instance of the PXCVideoModule from the face module instance and then after you prepared the images call the member function ProcessImageAsync(images, sp) of the PXCVideoModule instance. Since the processing is asynchronous, you need to synchronize (call sp->Synchronize())with the PXCSyncPoint* sp before updating the face data.
You can also have a look here https://software.intel.com/en-us/forums/realsense/topic/606341#comment-1861247​ (this first big block of code in message 20) for some example code and more details.
Good luck!
