I'm trying to configure ios pushes using this tut : http://qnimate.com/push-notification-in-intel-xdk-using-push-plugin/
i'm having a problem : how to generate PEM file using .cer on windows ?
its written i have to enter command lines with openssl but i have to use private key.
I think the private is used to generate CSR, that intel provides us.
can anyone tell me how to proceed to generate pem files to activate pushes on ios on google could messaging ?
Thanks & Regards
Shamsul Aarifeen
- Tags:
- HTML5
- Intel® XDK
Please give me the solutions of our post its very urgent.
Thanks & Regards
Shamsul Aarifeen
you need to generate a private key and push certificate
Here is the article through which you can create certificate, provisioning profile step by step:
https://software.intel.com/en-us/xdk/docs/building-cordova-ios-apps-intel-xdk
This might be helpful:
