Software Archive
Read-only legacy content
17060 Discussions
How do I get the refresh rate of the monitor using GetCloneRefreshRates ?
xqin01
Display_Config data;
data.uidMonitorPrimary = 4096;
m_pCUIExternal8->GetCloneRefreshRates(sizeof(Display_Config), (BYTE*)&data, MAX_REFRESH_RATE, (BYTE*)&rate, (BYTE*)&rate2, &dwExtraErrorCode);
4096 is obtained using EmemActiveDevices.
used this method,the parameters are passed in correctly?If not, how do you pass the value.
I hope the expert will give me a suggestion.
