Software Archive
Read-only legacy content
17060 Discussions
How do I transfer contact from Android to iPhone after setup?
trump__jenny
Transfer contacts with a Google account
For belt and braces, and to make sure this process always works in future, consider doing the following, either on your iPhone after you've followed the steps above, or on your Android before you make the move:
  1. Open the Settings application on your iPhone.
  2. Select Accounts & Passwords (or Mail, Contacts, Calendars on older versions of iOS).
  3. Select Add Account.
  4. Select Other.
  5. Select Add CardDAV Account.
  6. Fill out your account information in the following fields:Server: Enter "google.com" User Name: Enter your full Google Account or Google Apps email address. Password: Your Google Account or Google Apps password. (If you've enabled two-step verification, you'll need to generate and enter an application-specific password.)Description: Enter a description of the account (such as Personal Contacts).
  7. Select Next at the top of your screen.
  8. Make sure the Contacts option is set to ON.
After you've completed the setup process, open the Contacts app on your device, and syncing will automatically begin between your iPhone and Google.
Smith__Fespop
For belt and braces, and to make sure kodi this process always works in future, consider doing the following, either on your iPhone after you've followed the steps above, or on your Android before you make the move:
  2. Select Accounts & Passwords (or Mail, Contacts, showbox Calendars on older versions of iOS).
  4. Select Other.
  7. Server: Enter "google.com"
  8. User Name: Enter your full Google Account or Google Apps email address.
  9. Password: Your Google Account or Google Apps password. (If you've enabled two-step verification, you'll need to generate and enter an application-specific password.)
  10. Description: Enter a description of tutuapp the account (such as Personal Contacts).
  11. Select Next at the top of your screen.
  12. Make sure the Contacts option is set to ON.
After you've completed the setup process, open the Contacts app on your device, and syncing will automatically begin between your iPhone and Google. Any time you set up any smartphone, Google should hold the key to all of your contacts.
CSpot
It would better if you sync all your contacts with Google and later download it into another bu just signing in your email.
