Software Archive
Read-only legacy content
17060 Discussions
How to abort application once error encountered in offloaded section
Abhishek_S_7
I am having a  C parallel code. In this code there is a offload section using Cilk. Memory is being asigned in shared function. I want this application get aborted gracefully when error is encountered in offloaded section. How to do it.
abhishek
Sumedh_N_Intel
One of the ways you can do this is by returning a value back to host. Based on the return value the code code can continue executing or clean up and then exit the program.
