In order to allow bluetooth applications work in the background on iOS devices, there are couple of parameters which need to be appended to the Info.plist. Here is the documentation:
I thought of using hooks with cordoba-custom-config plugin but apparently XDK doesn't support hooks. So, what would be a proper XDK way to achieve the same result? Can this be automated with the XDK builds in some other way?
Thank you in advance...
- Tags:
- HTML5
- Intel® XDK
Generally, this can be done by creating a simple plugin that consists of a plugin.xml file with directives to add to your plist file. See this FAQ for some help > https://software.intel.com/en-us/xdk/faqs/general#android-manifest <
@Paul - thank you very much for the reference, it works fine now!
I really appreciate quick response, saved us tons of time.
