I'm using MPSS 3.4.3 on windows.
I challenged to change mac address of each mic device by modification of "micN.xml".
But, it failed.
I tried following step.
1, Modify mac address term of "micN.xml".
2, micctrl -r
3, micctrl --start
( I also tried PC reboot. )
How to change mac address of each mic device?
I can change IP address by above method & PC reboot (Not mic reboot), but MAC address is not changed...
What you did should have worked. Could you show us what the network section of your mic0.xml file looks like? You can use X's in place of digits if you to remove information specific to your site, but please keep the formatting of all the numeric fields. We can test it out and, if necessary, submit a problem report.
The micctrl command does seem to be ignoring the value set in the micN.xml file. I have filed a ticket for this problem.
