Hi guys,
I have a text area inserted in a gridlayout and want to change the text size.
I see that with this drag and drop the text is surrounded by <p> tags.
I've tried <p style="font-size:20px">, (also tried changing to %), but doesn't work.
What's the way to do this?
Thanks in advance.
- Tags:
- HTML5
- Intel® XDK
I recommend adding the font-size attribute directly to the textarea element.
textarea { font-size: 18px !important; }
The grid control has a text-size style that it uses to override the text of anything in the grid. You can remove that style if you don't want it. Or you can use it to make the desired adjustment.
