Software Archive
Read-only legacy content
17060 Discussions
How to change the IP 127.0.0.1 to localhost name in the XDK
Leonardo_M_1
 Hi!
     In my project I'm using a Facebook plugin to connect it, I need in the emulator run like a local hostname, and not with the IP.
John_H_Intel2
The facebook object is currently not implemented in the emulator. You will need to build your app to test it on device.
Leonardo_M_1
Ok, in this case, Intel XDK not support the facebook plugin?
John_H_Intel2
The XDK itself does not support the facebook plugin. You can build your app, install it on a physical device, and then test the configuration of the facebook plugin.
