Software Archive
Read-only legacy content
17060 Discussions
Failing to build cordova 3.5.1 application
Darren_G_
I'm trying to build a 3.5.1 application for iOS, but despite updating all the details in projects tab, the build fails. The build log reports - building a Cordova 3.3 application... and then errors at Error: Plugin "org.apache.cordova.network-information" (0.2.8) failed to instal
Clearly it's trying to build a 3.3 application rather than 3.5.1, but why?! I've specified the correct CLI version in the projects tab, for all devices.
Any help appreciated :)
John_H_Intel2
You can not build 3.5.1 apps anymore. Please enter 3.5.  Here is the notice you should get when you try to build them using the XDK:
  • Error: "3.5.1" is not a supported Cordova version. Please specify Cordova 3.3, 3.5, 4.1, or 4.1.2.
Darren_G_
OK! Thanks John. Built successfully now.
