Software Archive
Read-only legacy content
17060 Discussions
How to delete custom style
lqu
I create custom style in design mode, but i don't know how to delete it
John_F_3
Which CSS are you editing?  There appears to be multiple copies--the custom you create and the main that is built from the custom.
I tried to replicate a problem but partially successful.  The custom style did not return when I deleted from App Designer--but that was the style attached to the element.  I did notice the custom CSS was still there but not on the object I deleted it from. Deleting from the main.less.css it came back.  Deleting the custom.less.css did make it go away.
John_F_3
In AD, have you tried select, right click, and delete?
lqu
yes, I tried, but the style still in the css file. if i delete it from code mode then switch back to design mode, it comes back again.
John_F_3
lqu
Thanks, I was editing the main.less.css.
John_F_3
Hi Le,  Complicated to make it right in the IDE to have a global setting to purge all definitions if unused. Doesn't matter to have the old definition hanging around but adds to bloat. It would be nice to have the XDK take care of this automagically.
