Software Archive
Read-only legacy content
17061 Discussions
Illegal instruction using _mm512
George
Hello ,
I am using in my code intrinsics.
If I compile like:
icc -std=c99 -g -openmp -qopt-report=2 -o mycode mycode.c
I am receiving : Illegal instruction in line:
__m512 D = _mm512_set1_ps( FLT_MAX );
If I compile :
icc -std=c99 -g -mavx -openmp -qopt-report=2 -o mycode mycode.c
I am receiving: Illegal instruction in line:
__m512i tempy = _mm512_set1_epi32( y );
which is after "D" and after 'tempx , xIdx" . ( x and y are integers )
__m512i tempx = _mm512_set1_epi32( x );
__m512	xIdx  = _mm512_castsi512_ps( tempx );
__m512	yIdx  = _mm512_castsi512_ps( tempy );
Any ideas?
Thanks!
James_C_Intel2
Since this is the MIC forum, I assume you are trying to target a MIC processor, not AVX512, but whichever of those it is, you need to tell the compiler that that is what you are trying to do, since 512 bit operations are not valid on most machines.
So, add "-mmic" to your compiler flags to target the MIC, or consult the compiler manual to find the right flags for AVX512.
George
Ok, thanks , I misunderstood.
