How to delete iOS 8.0.1 update download from your device to avoid accidental installation?
Unfortunately it's no long possible to downgrade from iOS 8 to iOS 7 - Apple is no longer signing the iOS 7 images so won't be able to manually install the older images.
Step 1: Go to Settings > General > Usage > Manage Storage.
Step 2: Select “iOS 8.0.1.” Because it is over 1GB, it is probably towards the top of your list.
Step 3: Tap Delete Update, and tap Delete Update again to confirm.
This will effectively remove the downloaded update from your device and prevent you from accidentally installing it.
better way to degrade ios is to jailbrake and re-install software , you can get get the available versions of ios(7 6 8)
![](/skins/images/C4F7392A5C68ACA60290C9576F107044/responsive_peak/images/icon_anonymous_message.png)
Topic Options
