I recently got a Dell Venue 8 7000 tablet with the RealSense camera. Ideally, I'd like to find a way to create a 3D model with this camera, but there are no existing apps that can do this. My second best option would be to export the depth data. Is there a way to do this?
-Tim
Following up....anyone have any ideas on how best to do this, or if it's possible?
The RealSense SDK did not support Dell Venue 8 7000 tablet.
Thanks David. Do you know if there's another way to export depth data from a photo taken with the Dell Venue tablet?
If you can use OpenCV, I convert my depth stream images into an OpenCV mat. I then save that to a lossless file format and load it in elsewhere.
Hi, can you find the way to export the depth images? I am also looking how to export them. I am working on windows, and there is a tool called "Clip Editor", but it always fails and it looks like is exporting only the color images. Regards
You could get the depth images, convert them to OpenCV and then save them as png files for example.
