Software Archive
Read-only legacy content
17061 Discussions
How to get 1080p out of 3D Scan in C#
Gerardo_M_
Hello, I have been playing around with the F200 and SDK since a couple of weeks. I can say that the results are very impressive, however I noticed that the max resolutions coming out from the sample codes is 540, however camera is able to give 1080p.
How can I get 1080p resolution for 3D scan ?
samontab
Valued Contributor II
Colour camera can get you 1080p, but the depth camera has a maximum resolution of 640x480. So, you can't get 1080p for 3D (unless you interpolate the data).
Gerardo_M_
Hey thanks for your response, so, is there any tutorial I can follow to interpolate the data and get 1080p resolution, even more than 540p would be great.
samontab
You could do a simple linear interpolation yourself by just average the pixel values. If you need fancier interpolations you could use a library.
