Software Archive
Read-only legacy content
17060 Discussions
How to get 1920 x 1080 on 915gm - Asus VH242H monitor?
callummc
I have this laptop: http://vaio.sony.eu/view/ShowProduct.action?product=VGN-FJ1S&productFilters=retired&site=voe_en_GB_cons&pageType=Overview&category=VN+FJ+Series
I recently bought this monitor - http://www.provantage.com/asus-vh242h~7ASU90N0.htm
I have the two connected via VGA cable.
However, the problem is, the max resolution I can select is 1600x1200, however this does not look right and so I have to revert back to using 1280 x 800, on my brand new monitor capable of 1920x1080!
This is what I get from MonInfo:
Monitor
Model name............... ASUS VH242H
Manufacturer............. Asus
Plug and Play ID......... ACI24F3
Serial number............ 8CLMTF064017
Manufacture date......... 2008, ISO week 50
EDID revision............ 1.3
Input signal type........ Analog 0.700,0.000 (0.7V p-p)
Sync input support....... Separate
Display type............. RGB color
Screen size.............. 520 x 290 mm (23.4 in)
Power management......... Active off/sleep
Extension blocs.......... None
DDC/CI................... Not supported
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.644 - Ry 0.332
Green chromaticity....... Gx 0.286 - Gy 0.601
Blue chromaticity........ Bx 0.152 - By 0.076
White point (default).... Wx 0.313 - Wy 0.328
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 30-85kHz
Vertical scan range...... 55-75Hz
Video bandwidth.......... 160MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 148.500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
640 x 480p at 60Hz - IBM VGA
640 x 480p at 67Hz - Apple Mac II
640 x 480p at 72Hz - VESA
640 x 480p at 75Hz - VESA
800 x 600p at 56Hz - VESA
800 x 600p at 60Hz - VESA
800 x 600p at 72Hz - VESA
800 x 600p at 75Hz - VESA
832 x 624p at 75Hz - Apple Mac II
1024 x 768p at 60Hz - VESA
1024 x 768p at 70Hz - VESA
1024 x 768p at 75Hz - VESA
1280 x 1024p at 75Hz - VESA
1152 x 864p at 75Hz - VESA STD
1280 x 960p at 60Hz - VESA STD
1280 x 1024p at 60Hz - VESA STD
1440 x 900p at 60Hz - VESA STD
1680 x 1050p at 60Hz - VESA STD
1920 x 1080p at 60Hz - VESA STD
Report information
Date generated........... 11/03/2009
Software revision........ 2.30.0.793
Operating system......... 5.1.2600.2.Service Pack 2
Raw data
00,FF,FF,FF,FF,FF,FF,00,04,69,F3,24,11,FA,00,00,32,12,01,03,68,34,1D,78,2A,C7,20,A4,55,49,99,27,
13,50,54,BF,EF,00,71,4F,81,40,81,80,95,00,B3,00,D1,C0,01,01,01,01,02,3A,80,18,71,38,2D,40,58,2C,
45,00,09,25,21,00,00,1E,00,00,00,FF,00,38,43,4C,4D,54,46,30,36,34,30,31,37,0A,00,00,00,FD,00,37,
4B,1E,55,10,00,0A,20,20,20,20,20,20,00,00,00,FC,00,41,53,55,53,20,56,48,32,34,32,48,0A,20,00,52
and the graphics card info:
Intel Graphics Media Accelerator Driver for Mobile Report
Report Date: 03/11/2009
Report Time[hr:mm:ss]: 13:51:49
Driver Version: 6.14.10.4764
Operating System: Windows XP* Home Edition, Service Pack 2 (5.1.2600)
Default Language: English
DirectX* Version: 9.0
Physical Memory: 2038 MB
Minimum Graphics Memory: 8 MB
Maximum Graphics Memory: 128 MB
Graphics Memory in Use: 14 MB
Processor: x86 family 6 Model 13 Stepping 8
Processor Speed: 1729 MHZ
Vendor ID: 8086
Device ID: 2592
Device Revision: 03
* Accelerator Information *
Accelerator in Use: Mobile Intel 915GM/GMS,910GML Express Chipset Family
Video BIOS: 1220
Current Graphics Mode: 1280 by 800 True Color (60 Hz)
* Devices Connected to the Graphics Accelerator *
Active Notebook Displays: 1
* Notebook *
Monitor Name:
Display Type: Digital
Gamma Value: 3.54
DDC2 Protocol: Supported
Maximum Image Size: Horizontal: Not Available
Vertical: Not Available
Monitor Supported Modes:
1280 by 800 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Supported
* SDVO Encoder Report *
** Encoder 1 **
Vendor ID: Silicon Image
Device ID: 170
Device Revision: 2
Major Version: 1
Minor Version: 0
I heard I may be able to achieve this through DTD calculator, I do not know how to operate it though, so any help would be gratefully received! Thankyou.
callummc
Oh, I just found out that Sony are blocking 1920 x 1080, but it is possible to get 1918 x 1200. could someone tell me the DTD code for that? thanks!
Aaron_B_Intel
Quoting - callummc
02 3A 7E 1A 71 38 2D 40 5A 2C 45 00 09 25 21 00 00 1E
callummc
thankyou so so much! it worked. im so grateful! :)
nickardo
Quoting - callummc
Thanks for this thread it worked for me
koi
