Software Archive
Read-only legacy content
17061 Diskussionen
How to get 1920 x 1080 on 915gm - Asus VH242H monitor?
callummc
Einsteiger
975Aufrufe
I have this laptop: http://vaio.sony.eu/view/ShowProduct.action?product=VGN-FJ1S&productFilters=retired&site=voe_en_GB_cons&pageType=Overview&category=VN+FJ+Series
I recently bought this monitor - http://www.provantage.com/asus-vh242h~7ASU90N0.htm
I have the two connected via VGA cable.
However, the problem is, the max resolution I can select is 1600x1200, however this does not look right and so I have to revert back to using 1280 x 800, on my brand new monitor capable of 1920x1080!
This is what I get from MonInfo:
Monitor
Model name............... ASUS VH242H
Manufacturer............. Asus
Plug and Play ID......... ACI24F3
Serial number............ 8CLMTF064017
Manufacture date......... 2008, ISO week 50
EDID revision............ 1.3
Input signal type........ Analog 0.700,0.000 (0.7V p-p)
Sync input support....... Separate
Display type............. RGB color
Screen size.............. 520 x 290 mm (23.4 in)
Power management......... Active off/sleep
Extension blocs.......... None
DDC/CI................... Not supported
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.644 - Ry 0.332
Green chromaticity....... Gx 0.286 - Gy 0.601
Blue chromaticity........ Bx 0.152 - By 0.076
White point (default).... Wx 0.313 - Wy 0.328
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 30-85kHz
Vertical scan range...... 55-75Hz
Video bandwidth.......... 160MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 148.500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
640 x 480p at 60Hz - IBM VGA
640 x 480p at 67Hz - Apple Mac II
640 x 480p at 72Hz - VESA
640 x 480p at 75Hz - VESA
800 x 600p at 56Hz - VESA
800 x 600p at 60Hz - VESA
800 x 600p at 72Hz - VESA
800 x 600p at 75Hz - VESA
832 x 624p at 75Hz - Apple Mac II
1024 x 768p at 60Hz - VESA
1024 x 768p at 70Hz - VESA
1024 x 768p at 75Hz - VESA
1280 x 1024p at 75Hz - VESA
1152 x 864p at 75Hz - VESA STD
1280 x 960p at 60Hz - VESA STD
1280 x 1024p at 60Hz - VESA STD
1440 x 900p at 60Hz - VESA STD
1680 x 1050p at 60Hz - VESA STD
1920 x 1080p at 60Hz - VESA STD
Report information
Date generated........... 11/03/2009
Software revision........ 2.30.0.793
Operating system......... 5.1.2600.2.Service Pack 2
Raw data
00,FF,FF,FF,FF,FF,FF,00,04,69,F3,24,11,FA,00,00,32,12,01,03,68,34,1D,78,2A,C7,20,A4,55,49,99,27,
13,50,54,BF,EF,00,71,4F,81,40,81,80,95,00,B3,00,D1,C0,01,01,01,01,02,3A,80,18,71,38,2D,40,58,2C,
45,00,09,25,21,00,00,1E,00,00,00,FF,00,38,43,4C,4D,54,46,30,36,34,30,31,37,0A,00,00,00,FD,00,37,
4B,1E,55,10,00,0A,20,20,20,20,20,20,00,00,00,FC,00,41,53,55,53,20,56,48,32,34,32,48,0A,20,00,52
and the graphics card info:
Intel Graphics Media Accelerator Driver for Mobile Report
Report Date: 03/11/2009
Report Time[hr:mm:ss]: 13:51:49
Driver Version: 6.14.10.4764
Operating System: Windows XP* Home Edition, Service Pack 2 (5.1.2600)
Default Language: English
DirectX* Version: 9.0
Physical Memory: 2038 MB
Minimum Graphics Memory: 8 MB
Maximum Graphics Memory: 128 MB
Graphics Memory in Use: 14 MB
Processor: x86 family 6 Model 13 Stepping 8
Processor Speed: 1729 MHZ
Vendor ID: 8086
Device ID: 2592
Device Revision: 03
* Accelerator Information *
Accelerator in Use: Mobile Intel 915GM/GMS,910GML Express Chipset Family
Video BIOS: 1220
Current Graphics Mode: 1280 by 800 True Color (60 Hz)
* Devices Connected to the Graphics Accelerator *
Active Notebook Displays: 1
* Notebook *
Monitor Name:
Display Type: Digital
Gamma Value: 3.54
DDC2 Protocol: Supported
Maximum Image Size: Horizontal: Not Available
Vertical: Not Available
Monitor Supported Modes:
1280 by 800 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Supported
* SDVO Encoder Report *
** Encoder 1 **
Vendor ID: Silicon Image
Device ID: 170
Device Revision: 2
Major Version: 1
Minor Version: 0
I heard I may be able to achieve this through DTD calculator, I do not know how to operate it though, so any help would be gratefully received! Thankyou.
4 Antworten
callummc
Einsteiger
975Aufrufe
Oh, I just found out that Sony are blocking 1920 x 1080, but it is possible to get 1918 x 1200. could someone tell me the DTD code for that? thanks!
Aaron_B_Intel
Mitarbeiter
975Aufrufe
Quoting - callummc
02 3A 7E 1A 71 38 2D 40 5A 2C 45 00 09 25 21 00 00 1E
callummc
Einsteiger
975Aufrufe
thankyou so so much! it worked. im so grateful! :)
nickardo
Einsteiger
975Aufrufe
Quoting - callummc
Thanks for this thread it worked for me
koi
Antworten
