Software Archive
Read-only legacy content
17060 Discussions
How to get rid of console errors
David_K_6
I regularly receive the following error in my app:
Uncaught TypeError: Cannot read property 'call' of undefined target-script-min.js:1283
This seems to be benign, but it would be nice to get rid of it, Any ideas?
It goes away if I remove the weinre script, of course.
(Apologies if anyone saw the earlier version of this post, which had some spurious stuff on it)
PaulF_IntelCorp
I assume you are not keeping the weinre script in your app when you publish it? That's not a good idea, it should be removed from your app before you publish your app.
Are you getting this when using the Emulate tab? If so, it can be ignored.
David_K_6
I've been sane enough to remove it from most of the beta test builds (although I have been forgetting some, which is embarrassing).
I do have a zero-tolerance approach to console errors, though, so I don't really like the idea of "just ignoring it". So I guess that since I don't use the weinre debugger often (I either debug on the emulator, or use trace statements on a real machine), I'll just leave the script out most of the time unless needed.
Having said which, it wouldn't be a difficult thing for your developers to fix: all it needs is to make the following change to line 1283, from
return xhr.httpSocketHandler.call(xhr.httpSocket, xhr);
to
if (xhr.hasOwnProperty('httpSocketHandler')) {
If you can alert developers of this, that would be nice...
