Software Archive
Read-only legacy content
17060 Discussions
Intel XDK Cordova geolocation issue
Rares_H_
Hello fellow developers,
I am having a bit of an issue with the cordova geolocation plugin.
I am trying to get my position with the geolocation plugin but if the GPS Location is turned off before i open the app, i can prompt the message to ask the user to turn it on ( not like other native apps, just a simple notice ) but until he restarts the app, the location is not triggered.
Is there a way to fix this ?
If the location is turned on before the app launches everything works ok until it is turned off while the app is running, if it is turned off and then back on, it stops working again.
I am hoping there is a way for force start the location GPS on the device while the app is running without having to restart the app.
The tests were on  Android 5.1.1 / Sony Xperia Z3 Compact
Thank you!
Rares_H_
Just found this sample : https://github.com/xmnboy/hello-cordova
it seems to work as i desire, so i will start debugging and comparing with what i have.
Hope that sample helps anybody else.
Dani_Carla
Hi Rares H.
I'm with the same problem.
You find a solution?
Rares_H_
Hey Carla,
I scraped the HelloCordova APP and made it work with my conditions
Remove from cordova-geo.js what you don't need and it should work.
I included the utils , cordova-geo and the triggers in my own init-app.js
Best of luck.
